edperez5000
Jun 11, 2019Guide
Netgear XR500 reboot and restart WIFI
Hi is there a way that when my house electric power goes off and then the electric power goes back on my Netgear XR500 WIFI is off. I need it on so that I don't have to press the buttons on the unit...
- Jun 11, 2019
You are correct for some weird reason when I rebooted both ways it started WIFI automatically. So I thank you but I don't know what happen that it did not work in the morning.
edperez5000
Jun 11, 2019Guide
Thank you but no I don't have to do the setup again all I have to do is press the WIFI button to turn on the router. But this should be automatic once the router is on Wifi should also turn on without me having to press the button. Even after a normal reboot Wifi button is not lit and is not Wifi is not on.
Netduma-Fraser
Jun 11, 2019NetDuma Partner
A reboot the WiFi should definitely be on, how do you do a reboot - by unplugging from power or through the interface?
