mikew2
Jun 13, 2023Aspirant
Netgear xr500 resets randomly
Hi, I have the Netgear XR500. It will completely reboot, seems like this is a common issue. I have followed the following troubleshooting: Factory reset. Plugging the power cable directly into th...
Jun 14, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channel configurations are currently set on the router?
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
- mikew2Jun 14, 2023Aspirant
Firmware V2.3.2.134
Calix Gigapoint 803G
LAN Cable is CAT6.
The issue is only since switching to this router. It is temping to just use the ISP router since it never disconnects.
I have set the DHCP range between 50 and 254. Reserved IPs for all devices.
Channel configuration: Smart connect enabled. Channel Auto for 2.4GHZ and 153 for 5GHZ
