mikew2
Jun 13, 2023Aspirant
Netgear xr500 resets randomly
Hi, I have the Netgear XR500. It will completely reboot, seems like this is a common issue. I have followed the following troubleshooting: Factory reset. Plugging the power cable directly into th...
mikew2
Jun 14, 2023Aspirant
Ok. I confirmed under LAN Setup that the DHCP range is 50 to 254. I have every device reserved IP from 1 to 10.
For clarification. When it disconnects it is every device disconnecting, Wireless and LAN.
I'll try rebooting from the interface and see. The disconnects are a couple times throughout the day. It disconnects every device, wireless and LAN.
Jun 14, 2023Guru - Experienced User
Please set the smaller DHCP IP address range.
Be sure that any Reserved IP address that is set ON the router is with in this smaller IP address range.
For any STATIC IP address configurations set ON devices, should be outside of the smaller IP address range.
- mikew2Jun 14, 2023Aspirant
Appreciate the help. Just to clarify. We are setting the DHCP range from 100 to 200. We want the reserved addresses to be outside this range, at least that is what I understand. I have every device reserved from 192.168.1.1 to 11 and that is what is showing under device manager.
- Netduma-FraserJun 14, 2023NetDuma PartnerYes that all sounds good!
