Invokes
Feb 19, 2020Follower
Netgear XR500 setup for HFC NBN
Hi all, Have XR500 gaming router. Trying to connect HFC NBN. Supplier told me to I need to configure router to PPPoE, VLAN ID 2 and input username and password to connect to internet. I have se...
Netduma-Fraser
Feb 20, 2020NetDuma Partner
Go to Settings > Advanced Settings > VLAN/Bridge Settings, then choose VLAN Tag group, edit the existing rule and change the ID to 2 and then apply. There should be no reason that it doesn't work with your ISP.
