LouMano
Mar 31, 2018Aspirant
Netgear Xr500: sliders does no affect to download speed
So I have purchased the Netgear Xr500 after many years of use on the NetDuma R1. I have my download speeds set up which I’m currently getting 329 Mbps download and 12 Mbps upload. My Xbox gets the ma...
Netduma_Jack
Mar 31, 2018NetDuma Partner
Hi Lou,
Two things to check. First:
1. Set the mode to 'Always' and try again. If you had it on 'High Priority Traffic Detected' mode it will only apply the limits when a game is being played
If that doesn't work, then:
2. Disable IPv6 if you've enabled it. Also, if you're using PPPoE, enter your credentials in your modem instead of the XR500
- LouManoMar 31, 2018AspirantHey thank you for the advice, it is working. I am currently having trouble with my NAT type on Xbox now tho. It won’t register, I have UPNP disabled and everything port forwarded. It seems when I have it on filtering mode it will go into not registering my NAT
- LouManoMar 31, 2018AspirantAlso I am having problems joining friends party chat as well, it will not let me connect. I know when I had my Linksys I never had this problem
- XRaptor29Mar 31, 2018LuminarySame here, putting it in spectator mode fixed it for me. I think Xbox Live is down on the east coast because when I put it in spectator mode I went all the way to California for a server.
- Netduma-FraserApr 01, 2018NetDuma PartnerThat's the Geo-Filter causing a false reading. It doesn't mean your NAT is bad, just that it can't get a reading from the server is blocked. Putting in Spectator Mode for boot up, check NAT then put in Filtering Mode. If you find the server that's being blocked on the Geo-Filter please let us know and we can add it to the Geo-Filter cloud to be automatically allowed.
