LouMano
Mar 31, 2018Aspirant
Netgear Xr500: sliders does no affect to download speed
So I have purchased the Netgear Xr500 after many years of use on the NetDuma R1. I have my download speeds set up which I’m currently getting 329 Mbps download and 12 Mbps upload. My Xbox gets the ma...
Netduma_Jack
Mar 31, 2018NetDuma Partner
Hi Lou,
Two things to check. First:
1. Set the mode to 'Always' and try again. If you had it on 'High Priority Traffic Detected' mode it will only apply the limits when a game is being played
If that doesn't work, then:
2. Disable IPv6 if you've enabled it. Also, if you're using PPPoE, enter your credentials in your modem instead of the XR500
LouMano
Hey thank you for the advice, it is working. I am currently having trouble with my NAT type on Xbox now tho. It won’t register, I have UPNP disabled and everything port forwarded. It seems when I have it on filtering mode it will go into not registering my NAT
