ArchEnemy
Nov 23, 2020Aspirant
Netgear XR500 Speed slower than Modem
Hi I recently purchased a Netgear XR500. When I set up my internet at first boot, it is able to detect my full speeds (300/15). After connecting to it via Wifi, I found that the speed on my XR500 (15...
Netduma-Fraser
Nov 23, 2020NetDuma Partner
There may be quite a few WiFi networks in your area so use a WiFi analyzer to find the least congested channels and change to those. Also ensure there are no electrical devices within the proximity of the router as that could interfere with the signal.
- ArchEnemyNov 23, 2020Aspirant
No I don't think there are any interferences. It is sitting right in the middle of the home, on the top shelf in an open space. There are no electronic devices in the vicinity, besides the Modem that is around 50cm away from the Router. I have tried switching the channel to a different one but no improvements.
- Netduma-FraserNov 24, 2020NetDuma PartnerCould you provide a screenshot of the Advanced WiFi settings please? Did you use a WiFi analyzer when you changed channel? It's important to get one that isn't congested.
