MrBullit
Sep 09, 2019Aspirant
Netgear xr500 SSD problem
Hallo! My Netgear xr500 doesn't recognize the Samsung Portable SSD T5 (1TB). On the other hand, it does recognize a normal USB-Stick. Thanks for your help!
- Sep 09, 2019
a couple things. Did you check the compatiblity list.
https://kb.netgear.com/18985/Will-my-USB-drive-work-with-ReadySHARE
its not all encompassing but its known devices to work. Another thing, do you have it formatted correctly?
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-my-Nighthawk-router
MrBullit
What i forgot to mention:
I can add the ssd to the trusted devices, but the ssd does't show at the readyshare-folder.
Thanks!
- plemansSep 09, 2019Guru - Experienced User
