Coolmarch22
Nov 12, 2020Aspirant
Netgear XR500 USB Control Center Not Appears Printer
Dear All I have Router Netgear XR500, now USB Control Center Not Appear Printer Last month i can print via Wifi and on USB Control Center Appears the Printer. But Now Suddenly The Printer is...
Netduma-Fraser
Nov 13, 2020NetDuma Partner
As I work for Netduma and there aren't any settings on the router interface at all for this functionality there isn't much I can advise except maybe check the USB connection is connected properly.
Coolmarch22
Nov 14, 2020Aspirant
I have disconnect and reconnect the usb to other usb port on router, still the printer not appears
- Netduma-FraserNov 14, 2020NetDuma PartnerI'd recommend creating a ticket here with Netgear support as they will likely have more suggestions: http://support.netgear.com/
- Coolmarch22Nov 15, 2020Aspirant
I bought the router overseas
Netgear in my country not support XR500
Also now i can't stream video trough Wifi
- Netduma-FraserNov 16, 2020NetDuma PartnerVideo through WiFi is that related to the USB issues or just streaming video like YT etc? What speeds do you pay for/expect? What devices are you having trouble on?
