Billieg42
May 01, 2019Follower
NetGear XR500
Can Express VPN be installed on my rig?
Netduma-Fraser
May 01, 2019NetDuma Partner
Yes all you need to do is obtain the OpenVPN config files from Express and then input that into the advanced setup of Hybrid VPN and enter your login details.
