jdennis1014
Nov 27, 2021Aspirant
Netgear XR500
I’m getting really slow upload speeds on my PS4 Pro hooked up through my xr500. My internet speeds are 900mbps download and 18mbps upload. When I test my speed through the PS4 Pro I’m getting a good d...
Netduma-Fraser
Nov 28, 2021NetDuma Partner
Are you connected via WiFi or ethernet? What is the model of the modem/router the XR is connected to? Console speed tests are not always accurate, if you do a speed test on a PC and it's getting the correct speeds then it likely is on the console as well.
jdennis1014
Nov 28, 2021Aspirant
I’m connected by Ethernet, I have the xfinity XB7 in bridge mode.
- Netduma-FraserNov 28, 2021NetDuma PartnerIf you upload a large gameplay from the PS4 for example, what speed does it upload at?
- jdennis1014Nov 28, 2021AspirantNot sure what u mean by uploading a large gameplay. I don’t do any live steaming, just online multiplayer gaming COD.
- Netduma-FraserNov 28, 2021NetDuma PartnerIf you just do a recording of some gameplay and then upload it to YT - you could do it unlisted for example and then you can see at what speed it is uploading, seeing whether the speed test is correct or not.
