jdennis1014
Nov 27, 2021Aspirant
Netgear XR500
I’m getting really slow upload speeds on my PS4 Pro hooked up through my xr500. My internet speeds are 900mbps download and 18mbps upload. When I test my speed through the PS4 Pro I’m getting a good d...
jdennis1014
Nov 28, 2021Aspirant
Did the speed test I got 917.85 download and 18.58 upload ping 22
Netduma-Fraser
Nov 28, 2021NetDuma Partner
Okay great so the console is receiving the speeds it's supposed to be, the in built test just won't be as accurate
- jdennis1014Nov 28, 2021AspirantGot online to game and got slow upload speed again. I went to do another speed test and now my upload speed says a socket error and want get me a speed reading
- Netduma-FraserNov 28, 2021NetDuma PartnerIt's likely just the test misbehaving, if you're able to play a game then your upload speed will be fine
- jdennis1014Nov 28, 2021AspirantI’m able to play but I’m experiencing laggy game play when I’m in game. When I’m at the scene to start a game images takes a long time to load
- jdennis1014Nov 28, 2021AspirantAlso I went to setup my lan connect in my PS4 Pro I manually enter all the information I used the Google dns and ran my test connection speed was still very low. I went into the XR500 log in page the XR500 has my dns has what my ISP has provided. Does this need I can’t use the Google dns?
- Netduma-FraserNov 29, 2021NetDuma PartnerIf that was the speed at fault that would be the download. What ping are you seeing in game and via the Geo-Filter?
You should set DNS via the router compared to the device, would also suggest using automatic settings on the console. - jdennis1014Nov 29, 2021AspirantOk I will try this out. Do you think putting in a new dns setting in the xr500 will give me faster download and upload speed?
- Netduma-LiamNov 30, 2021NetDuma Partner
Let us know how you get on! No, DNS will have very little affect on your bandwidth speeds.
- jdennis1014Nov 30, 2021AspirantPlayed a few games only 1 game turned out well ping in game was 29ms to 32ms. Looks like I was pinged on a dedicated server. The rest of the games pinged in the 59ms to 75ms. Modern warfare in game search ping was 71ms to 90ms. I have my ping set to 30ms. Also I was thinking of getting rid of my xfinity XB7 modern router combo. Whats a good modem that will match up to the Nighthawk XR500.
- Netduma-LiamDec 01, 2021NetDuma Partner
In future, try denying the servers that aren't giving you a good experience. I don't have any personal reccomendations on a modem myself, I simply use the ISP provided one currently.
