Asabat
Apr 08, 2020Aspirant
NetGear XR700 Plex Media Server status “No USB Device Connected”
I am attempting to set up Plex Media Server on new XR700 router, but it does not recognize my external hard drive when it is plugged in. I am using a 2TB Seagate HDD formatted at NTFS with 6 GB fre...
- Apr 08, 2020Does the router identify the HD in ReadyShare at all? If it doesn't then it may not be compatible, if it does then this may be a plex issue. What firmware version are you on?
Asabat
Apr 09, 2020Aspirant
My firmware version of the router is V1.0.1.20
And i am using a Seagate 2 TB Backup Plus Slim
I believe this is a supported device.
Asabat
ReadyShare was not recognizing it either. I tried a Sandisk USB and that was recognized.
Then I tried my 8TB Seagate BackUp Plus Hub and that was recognized as well.
That was the issue, somehow the typical Seagate 2TB is not supported?
I guess I will use my 8TB for the Plex Server.
Thanks for the help!
- Netduma-FraserApr 09, 2020NetDuma PartnerSeems that way, I'm not sure why some are supported and others aren't but glad you're able to use Plex now.
