Tony-Dewhurst
May 12, 2019Tutor
Netgear XR700 Sluggish Performance and Losing WAN
Having a few issues with the router done the same test with a R7000 with Merlin WRT and there are no issues..
Is this expected performance fto 100% cpu from a xr700 downloading a single torren...
Netduma_Alex
May 13, 2019NetDuma Partner
This sounds like something you might need to contact NETGEAR support about. This router should be able to handle much more than you're throwing at it here.
