Tony-Dewhurst
May 12, 2019Tutor
Netgear XR700 Sluggish Performance and Losing WAN
Having a few issues with the router done the same test with a R7000 with Merlin WRT and there are no issues..
Is this expected performance fto 100% cpu from a xr700 downloading a single torren...
May 13, 2019Guru - Experienced User
Try downgrading FW to 1.0.0.20
FYI, (x)WRT is not supported on the R7000...So test comparison isn't really valid.
Tony-Dewhurst
May 16, 2019Tutor
This is the version of XWRT i have installed
And it does support the r7000!
