Vger2
May 14, 2023Aspirant
Netgear XR700 wifi router separate SSID's issue
Having an issue with my Nighthawk XR700 router. Has been working OK until yesterday. On the most current firmware. I've configured the router with Smart Connect disabled and using two separate SSID's ...
Netduma-Fraser
May 14, 2023NetDuma Partner
It may be a coincidence that Smart Connect being re-enabled caused you to get internet again as it would restart that connection cycle. What is the model of the modem/router that the XR is connected to?
Vger2
Yes, currently using a Motorola - MB8600 32x8
DOCSIS 3.1 Cable Modem 1 GB Ethernet.
Strange that everything was working before and it just suddenly stopped working with the separate SSID's configuration and Smart Connect disabled.
