charleyshf
Sep 13, 2022Tutor
Netgrear XR1000 Won;'t handle 1GB download speeds?
I have had issues before with my XR1000, but this one is troubling. About a week ago we upgraded our internet speeds from 400mbps to 1000mbps download speeds. When I am directly connected to the cabl...
Sep 13, 2022Guru - Experienced User
What cable modem are you connected to?
have you manually went in a set you speeds to gigabit?
DumaOS Optimal Settings Guide: Maximum Bandwidth Speeds : NETDUMA
charleyshf
Sep 13, 2022Tutor
Hello,
It's a EU2551 Specs are here - https://d15yx0mnc9teae.cloudfront.net/sites/default/files/2018-08/spectrum_d31_emta_data_sheet.pdf
Manually set the speeds, are you taking about the XR1000 itself as I have done that, or is there a way to change it on the cable modem?
Thanks
- Netduma-LiamSep 13, 2022NetDuma Partner
How are you measuring the speeds? Are you using a third-party speed-test such as speedtest.net? Or are you using the in-built Connection Benchmark?
- charleyshfSep 13, 2022Tutor
Hello,
I am using speedtest.net to run the tests.,.
- Netduma-FraserSep 13, 2022NetDuma PartnerDid you do the steps above to fully disable QoS to see if speeds are higher?
