charleyshf
Sep 13, 2022Tutor
Netgrear XR1000 Won;'t handle 1GB download speeds?
I have had issues before with my XR1000, but this one is troubling. About a week ago we upgraded our internet speeds from 400mbps to 1000mbps download speeds. When I am directly connected to the cabl...
Sep 13, 2022Guru - Experienced User
What cable modem are you connected to?
have you manually went in a set you speeds to gigabit?
DumaOS Optimal Settings Guide: Maximum Bandwidth Speeds : NETDUMA
correct, in the router. There isn't anything in the modem.
did you disable qos?
- Go to QoS
- Click the three-line menu in top left corner of Congestion Control (Anti-Bufferbloat for older versions)
- Tick Disable QoS
- Run a third-party speed test (speedtest.net) from a device connected via ethernet (Not WiFi)
