thrull
Dec 04, 2020Aspirant
Nethawk XR300 slow speed using ONT direct connection
It seems that I have experienced the "100Mb/s" limit problem on WAN PORT. I am using XR300 with PPPoE configuration with fiber ONT directly connected to WAN port. QoS is disabled. IPv6 is disable...
Netduma-Fraser
Dec 04, 2020NetDuma Partner
In the Device Manager go to the table view, does it show the WAN port limited to 100Mbps?
- thrullDec 04, 2020Aspirant
It is 1Gb (with or without network switch between ONT and router):
WAN nil nil 1000Mbits
I think debug log also confirms as far as i understand:
==========================Internet IPv4/IPv6 connection debug log==============================
0 days 00:00:36, 1000M/Full
0 days 00:14:40, Link Down
0 days 00:15:11, 1000M/Full- thrullDec 05, 2020Aspirant
And passing through WAN connection through another router "solves" the situation. Not the solution most people will look for... Why the WAN port is so darn slow when using PPPoE with ONT? Or maybe it is ppp deamon?
- Netduma-FraserDec 05, 2020NetDuma PartnerThanks for the workaround, either PPPoE or VLAN must be causing that. I'll pass this on to the NG team and see if there is anything they can do.
