Zendorea
Jun 05, 2020Aspirant
Network bounces at 10:05 AM and PM EST Daily
So i have a weired issue. Router seems to be Bouncing at the same time daily. I worked with my ISP to narrow this down to the equipment plugged into the Cable Modem. Wanted to see if this has bee...
Netduma-Fraser
Jun 09, 2020NetDuma Partner
Go to Settings > Monitoring > Connection Status, does the DHCP Lease/obtained indicate that it is one day long?
Zendorea
Jun 09, 2020Aspirant
Hi,
Thanks for the response. I had to Downgrade the Firmware to V2.1.0.6 to fix the issue. Network is now stable after doing so.
I Can also Confirm that the DHCP lease was not the cause as the bounce occured exactly 12hrs apart daily and the DHCP renew from the ISP/Cable Modem was a week
