Zendorea
Jun 05, 2020Aspirant
Network bounces at 10:05 AM and PM EST Daily
So i have a weired issue. Router seems to be Bouncing at the same time daily. I worked with my ISP to narrow this down to the equipment plugged into the Cable Modem. Wanted to see if this has bee...
Zendorea
Jun 09, 2020Aspirant
Hi,
Thanks for the response. I had to Downgrade the Firmware to V2.1.0.6 to fix the issue. Network is now stable after doing so.
I Can also Confirm that the DHCP lease was not the cause as the bounce occured exactly 12hrs apart daily and the DHCP renew from the ISP/Cable Modem was a week
Netduma-Fraser
Jun 09, 2020NetDuma Partner
Great to hear that, let us know if you encounter it again.
