JonSnowKnowsNad
Jan 20, 2020Apprentice
Network Monitor Not accurate
Network Monitor is not showing how much internet each device is using accurately. I would do a speed test or watch a 4k video on my pc and it says my pc is using 0.002 download which has to be wrong....
Netduma_Alex
Jan 21, 2020NetDuma Partner
This is definately a bug. Could I ask what kind of internet connection settings you're using? PPPoE? Static? This might have some bearing on wether the bug occurs.
JonSnowKnowsNad
Jan 21, 2020Apprentice
where do i find that out
- Netduma-FraserJan 21, 2020NetDuma PartnerYou can find that in Settings > Internet Setup. When you look at the Network Monitor is it just before you start the video? It could be that when you're looking at it, it has buffered some of the video.
- JonSnowKnowsNadJan 21, 2020Apprentice
where it says internet IP address it says get dynamically from ISP. as for your question i would have two tabs opened up and side by side. one for watching the video in 4k and one for routerlogin.com to see my network monitor.
- Netduma-FraserJan 21, 2020NetDuma PartnerSo it doesn't say the connection requires a login? What is your exact physical setup? Are ALL devices connected to the router? How is the PC connected to the router?
