JonSnowKnowsNad
Jan 20, 2020Apprentice
Network Monitor Not accurate
Network Monitor is not showing how much internet each device is using accurately. I would do a speed test or watch a 4k video on my pc and it says my pc is using 0.002 download which has to be wrong....
JonSnowKnowsNad
Feb 04, 2020Apprentice
i've definitely played with the settings. im not sure what setting i changed that may have caused this.
Netduma-Fraser
Feb 04, 2020NetDuma Partner
Try doing a factory reset that case and then setup from scratch just doing basic settings - WiFi, QoS etc and see if it appears properly then.
- JonSnowKnowsNadFeb 04, 2020Apprentice
Factory reset did the trick! thanks man
- JonSnowKnowsNadFeb 05, 2020Apprentice
so i found out what it was. it was ipv6 being set on DHCP. when ipv6 is disabled network monitor is working 100% fine. is ipv6 being disabled perfectly fine because on default its disabled? would there be any issues if ipv6 is disabled?
- Netduma-FraserFeb 05, 2020NetDuma PartnerWell done on finding out the cause, we'll be sure to let our developers know. There won't be any issues by having IPv6 disabled.
