JonSnowKnowsNad
Jan 20, 2020Apprentice
Network Monitor Not accurate
Network Monitor is not showing how much internet each device is using accurately. I would do a speed test or watch a 4k video on my pc and it says my pc is using 0.002 download which has to be wrong....
Netduma-Fraser
Feb 04, 2020NetDuma Partner
Try doing a factory reset that case and then setup from scratch just doing basic settings - WiFi, QoS etc and see if it appears properly then.
JonSnowKnowsNad
Feb 04, 2020Apprentice
Factory reset did the trick! thanks man
