JonSnowKnowsNad
Jan 20, 2020Apprentice
Network Monitor Not accurate
Network Monitor is not showing how much internet each device is using accurately. I would do a speed test or watch a 4k video on my pc and it says my pc is using 0.002 download which has to be wrong....
Netduma-Fraser
Feb 04, 2020NetDuma Partner
Try doing a factory reset that case and then setup from scratch just doing basic settings - WiFi, QoS etc and see if it appears properly then.
JonSnowKnowsNad
Feb 05, 2020Apprentice
so i found out what it was. it was ipv6 being set on DHCP. when ipv6 is disabled network monitor is working 100% fine. is ipv6 being disabled perfectly fine because on default its disabled? would there be any issues if ipv6 is disabled?
- Netduma-FraserFeb 05, 2020NetDuma PartnerWell done on finding out the cause, we'll be sure to let our developers know. There won't be any issues by having IPv6 disabled.
