tcrmorrow
Aug 17, 2020Aspirant
Network speeds all over the place
I dont know whats going on but the router, for whatever reason is all over the place. Ive tried power cycling the router, and modem to no avail. Wirelss, Hardwired, Adapter properties, ans Router spe...
tcrmorrow
Aug 18, 2020Aspirant
Sure, I just did a "restore defaults" from within the router itself and its still slow. Now its up to 30 meg down through a browser..
tcrmorrow
I saved a backup config file and restored that so now the QoS page is litered again with devices I used once but never used again. This is kind of stupid that you cant delete these devices later.
- tcrmorrowAug 18, 2020Aspirant
Sorry here is the device manager page.
- Netduma-FraserAug 18, 2020NetDuma PartnerBy restoring using a config file you're restoring from a time where all those devices were connected. I would not suggest using that if you're trying to do a proper reset. In the Anti-Bufferbloat 3 line option menu disable QoS completely by clicking the check box, then do a speedtest, what do you get?
The speedtst went from 24 to 35 megs down, 11 up
