David2027
Dec 15, 2020Apprentice
Neuste Firmware Problem Nighthawk XR 500 Geo Filter
Moin Freunde, vielleicht könnt ihr mir helfen und zwar wenn ich die neuste Firmware auf meinem Nighthawk XR 500 installiere und ich dann mit meiner Ps4/5 ein Spiel suche und dann im Geo Filter beobac...
- Dec 16, 2020Sie müssen wahrscheinlich die Konsole vollständig ausschalten, dann die Geo-Filter-Cloud leeren, 2 Minuten warten, dann die Konsole einschalten und eine Suche versuchen.
David2027
Dec 29, 2020Apprentice
Netduma-Fraser
Dec 29, 2020NetDuma Partner
I think you've made it private so I can't view it
- David2027Dec 29, 2020ApprenticeYeah sorry, i changed it to public, now it should work
- Netduma-FraserDec 29, 2020NetDuma PartnerYeah it looks like the DHCP lease. Give your devices static IPs in LAN settings and if applicable give the XR a static IP on the ISP modem/router.
How to give the XR static Ip, my modem runs in full bridge mode with ip 192.168.1.1 then my XR with 192.168.1.2
- Netduma-FraserDec 29, 2020NetDuma PartnerWhat is your modem model? On that page you provided a picture of give your devices static/reserved IP addresses.
- David2027Dec 30, 2020Apprentice
My Modem Model is Drytek Vigor 165
I got again Disconnect every Day the Same...
Please can you take a look again at the new protokol ?
Okay you mean to give there a static ip to the modem or xr500 or both?
On the list down below of the screenshot?
- Netduma-FraserDec 30, 2020NetDuma PartnerOkay so it is a router, have you put the XR in the DMZ on the Draytek? Set a static IP for the XR on the Draytek
- David2027Dec 30, 2020ApprenticeNo, its a Modem, draytek vigor runs in full bridge mode, there are no options to do that!?!
Do you saw the new protokol from yesterday?
Netduma-Fraser - Netduma-FraserDec 31, 2020NetDuma PartnerIt's a router so you should be able to take it out of bridge mode, then apply a static IP to the XR and put it in the DMZ instead. Yes I did thanks for that.
- David2027Dec 31, 2020ApprenticeBut why should i do that, thout its better if i run it in bridge Mode, if the drytek is on router mode do i have a double nat?
- Netduma-FraserJan 01, 2021NetDuma PartnerBecause if the issue is that the XR is getting a new WAN IP and not connecting properly then this would fix that. The DMZ feature I mentioned would prevent a double NAT.
- David2027Jan 01, 2021ApprenticeHappy New Year, all the best for your family and you!
Ok and the XR is still DHCP Server or the Drytek?
Netduma-Fraser - Netduma-FraserJan 01, 2021NetDuma PartnerThank you, Happy New Year to you and yours as well!
Both still using DHCP yes, just give the XR a static IP on the Draytek. - David2027Jan 01, 2021ApprenticeThank you!
Yeah but can not be both DHCP Server, in one i have to unable, it just can be one dhcp server, you know what i mean? - Netduma-FraserJan 01, 2021NetDuma PartnerBoth can be a DHCP server, I assure you, that's how I have mine setup - ISP router (DHCP +XR500 static IP + in DMZ) > XR500 (DHCP)
Ok nice Thank you,
I gone change my Setup now from bridge to Router, will let you know when iam finish
- David2027Jan 01, 2021ApprenticeFirst Ip Conflict because both dhcp server and know i reset the xr500 know he cant find any internet conection when i start installing again, everything is right conected and drytek is on
- Netduma-FraserJan 01, 2021NetDuma PartnerTwo DHCP servers won't cause a conflict, one will be giving out IPs to devices in the 192.168.0.X range for example, the other in 192.168.1.x so no issues there. Did you set the same IP it already had as static?
- David2027Jan 01, 2021ApprenticeYeahh i fixed it, took some time before i came behind that thats the mistake was... I will Check Now, hope nomore disconnects , will let you know, thank you so much for everything so far!
- David2027Jan 02, 2021Apprentice
My Connection Crashed Again today, Telekom (iSP) was here and they said that is because of my Network, its not because of them, they checked everything outside.
Again because of Lease?
How do i find out, is it from the XR or Drytek?
- Netduma-FraserJan 02, 2021NetDuma PartnerLooks like it yes, give your devices static/reserved IPs in LAN Settings as well please and see if that helps.
- David2027Jan 04, 2021Apprentice
Again Disconnect,
i really dont know why...
Look at this DDos Attacks in that Time when i got Disconnect, maybe this could be the reason?
Got the Disconnect at time 22:48
- Netduma-FraserJan 04, 2021NetDuma PartnerThat's unlikely as the IP belongs to Amazon and DoS attacks are nothing to worry about - they're just connections you've come in contact with. Could you disable QoS entirely from the Anti-Bufferbloat 3 line option menu please and see if it still happens? If it does could you follow these instructions please and provide the information for TimChang so he can look into the issue please? https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR500-DHCP-issue/m-p/2023223/highlight/true#M23047
- David2027Jan 29, 2021ApprenticeHi my friend, i fixed the disconnects Problem, but now have new problem.
My Samsung TV, wont open any iptv they blocking everything, when i connect my samsung tv to my iphone then it opend any iptv channel without problems, what can i do here?
