Apr 06, 2022Guru - Experienced User
New - XR1000 Firmware Version 1.0.0.64 Released
New Features: 04/05/2022
Supports the Ad Blocker feature
Supports DNS over HTTPS (DoH)
Security Fixes:
Fixes security vulnerabilities.
For more information about security ...
MrMitsubishi
Jul 21, 2022Tutor
Seriously!
UPnP mode is still broken and won't enable for the past two years, and you decided to add two features when there's a lot of issues that are broken that been left unpatched for the past two year. When is UPnP going to be fixed? Geo-Filter doesn't work because i just played a COD lobby and lined a search area with 35ms selected with ping assist and I'm still getting put in 50+ lobbies with fast search turned off.
The old issues need to be fixed before we start new adding features.
Netduma-Liam
Jul 22, 2022NetDuma Partner
Since installing the latest firmware, did you factory reset the XR1000? If not, I'd suggest doing so. After installing the latest firmware and factory resetting I've not been able to reproduce the issue of UPnP not enabling/disabling.
