Apr 06, 2022Guru - Experienced User
New - XR1000 Firmware Version 1.0.0.64 Released
New Features: 04/05/2022
Supports the Ad Blocker feature
Supports DNS over HTTPS (DoH)
Security Fixes:
Fixes security vulnerabilities.
For more information about security ...
Netduma-Fraser
Jul 22, 2022NetDuma Partner
Can you provide a screenshot of your Geo-Filter page please? What do you mean QoS won't enable exactly - can you provide a screenshot of that page as well please?
Oct 05, 2022Guru - Experienced User
Posting this here for some testing results of the XR1000 on this version of FW and the Nighthawk app.
CAX80 modem mode. 1Gb/50Mbps ISP service
Default DCHP IP address pool range: 192.168.1.100 thru .200
Smart Connect and AX mode enabled
Manual Channels 1 and 40.
Beamforming and MIMO enabled.
40Mhz co-existence only on 2.4Ghz.
QoS enabled. Sliders both at 99% since I only game at night.
Nighthawk app on iPhone 12 pro max iOS 16:
2nd test after capturing this data got even worse: 372 on the down.
I'll check again later this evening. I presume this maybe a NH app speed test or the router picking a slower test site?
I get over 900Mpbs with the same NH app and iPHone and a RAX series router connected to same modem
Ooklas app on iPHone 12 pro max iOS 16:
Ooklas app on wired PC Windows 10x64:
