Apr 06, 2022Guru - Experienced User
New - XR1000 Firmware Version 1.0.0.64 Released
New Features: 04/05/2022
Supports the Ad Blocker feature
Supports DNS over HTTPS (DoH)
Security Fixes:
Fixes security vulnerabilities.
For more information about security ...
Netduma-Fraser
Dec 09, 2022NetDuma Partner
Set NAT to Open in WAN Settings, perhaps the firewall is blocking it
jeremyg237
Dec 09, 2022Luminary
Set Nat to open. However nothing changed. Any other suggestions?
- Netduma-FraserDec 09, 2022NetDuma PartnerDoes it work for other PCs as well and therefore purely affecting just the consoles?
- jeremyg237Dec 09, 2022Luminary
If I run a IPV6 test on PC it says is working. Do you have a method for me to check.
No problems detected.
You don’t have IPv6, but you shouldn’t have problems on websites that add IPv6 support.
Looks like I am not getting it on PC.
- Netduma-FraserDec 09, 2022NetDuma PartnerAre devices getting an IPv6 address in Device Manager and if so what does the beginning of the address start with?
I'm not seeing any device.
Im not seeing that on any device. Xbox, pc etc
I guarantee if I hook up the XR 500 I would get the IPV6.
- Netduma-FraserDec 10, 2022NetDuma PartnerCould you provide a screenshot of the IPv6 page on the 1000 please?
- jeremyg237Dec 10, 2022Luminary
Not sure what you need to see. If you would like to see everything I would feel more comfortable sending it to you directly than over a forum.
- Netduma-FraserDec 10, 2022NetDuma PartnerThat's fine thank you, set LAN to use DHCP Server instead then apply and see if that makes a difference
Ok looks like we have a solution. Thank you so much. I did the following as well.
Turned UONP back off
NAT back to secure
If you think I need to change any of this let me know.
- Netduma-FraserDec 10, 2022NetDuma PartnerGreat to hear that, those settings are good as you've set them
- jeremyg237Dec 11, 2022Luminary
Looks lie I lost IPV6 again this morning. However I am moving this to another thread because some other issues popped up.
