Apr 06, 2022Guru - Experienced User
New - XR1000 Firmware Version 1.0.0.64 Released
New Features: 04/05/2022
Supports the Ad Blocker feature
Supports DNS over HTTPS (DoH)
Security Fixes:
Fixes security vulnerabilities.
For more information about security ...
jeremyg237
Dec 10, 2022Luminary
Not sure what you need to see. If you would like to see everything I would feel more comfortable sending it to you directly than over a forum.
Netduma-Fraser
Dec 10, 2022NetDuma Partner
That's fine thank you, set LAN to use DHCP Server instead then apply and see if that makes a difference
- jeremyg237Dec 10, 2022Luminary
Ok looks like we have a solution. Thank you so much. I did the following as well.
Turned UONP back off
NAT back to secure
If you think I need to change any of this let me know.
- Netduma-FraserDec 10, 2022NetDuma PartnerGreat to hear that, those settings are good as you've set them
- jeremyg237Dec 11, 2022Luminary
Looks lie I lost IPV6 again this morning. However I am moving this to another thread because some other issues popped up.
