May 11, 2023Guru - Experienced User
New - XR1000 Firmware Version 1.0.0.68 Released
NOTE: This FW is for Version 1 of the XR1000 gaming router line. This version of FW is NOT compatible with hardware Version 2 of the XR1000 router series product line. The label under the router sho...
- Jul 20, 2023Looks like the issue for me is something to do with DHCP (yes I had the range set as 100-200) I set up my own DHCP server and set the lease time to 1 week and it's been stable ever since
omegavolpe
May 25, 2023Aspirant
Why is it recommended to limit the DHCP IP pool to only 100 addresses. I tried to do this but the router became unresponsive and had to revert the change. What should you do if you have more than 100 devices?
- FURRYe38May 25, 2023Guru - Experienced User
Then adjust if you have more than 100 devices.
