May 11, 2023Guru - Experienced User
New - XR1000 Firmware Version 1.0.0.68 Released
NOTE: This FW is for Version 1 of the XR1000 gaming router line. This version of FW is NOT compatible with hardware Version 2 of the XR1000 router series product line. The label under the router sho...
- Jul 20, 2023Looks like the issue for me is something to do with DHCP (yes I had the range set as 100-200) I set up my own DHCP server and set the lease time to 1 week and it's been stable ever since
Raustal
Jun 08, 2023Guide
I am curious to know if anyone uses Armor with this device? Are there any known issues by activating Armor and using the router's features? I know I initially had a paid subscription with my XR1000 about two-three firmware versions prior to the one listed here and I remember having issues with the device messing up to where I needed to factory reset it several times between several months of using it. I ended up disabling it and canceling my subscription to Armor becasue I wasn't sure if this was the cause. The problems eventually went away, but I do not know if it was a firmware update that resolved it or if it was because I stopped using Armor.
I want to know if any others have encountered issues with this service while using their device at any point.
- Netduma-FraserJun 08, 2023NetDuma PartnerWhat were the issues you were having exactly? Then we can determine whether Armor may have been the cause.
- RaustalJun 12, 2023Guide
Hey there! The router would give me errors when trying to login. I would get some UI loading problems, which I do not remember, and I would have to factory reset my router every so often. It has been a while since I had that problem. I was just curious about Armor because I was thinking of giving it another try and did not want to spend the money if it was buggy, or others were having issues with it of some sort.
- Netduma-FraserJun 12, 2023NetDuma PartnerUI loading could potentially be Armor yes, it's hard to give a definitive answer on this one, perhaps wait for the next firmware first which should be a big improvement then you could try it again.
