May 11, 2023Guru - Experienced User
New - XR1000 Firmware Version 1.0.0.68 Released
NOTE: This FW is for Version 1 of the XR1000 gaming router line. This version of FW is NOT compatible with hardware Version 2 of the XR1000 router series product line. The label under the router sho...
- Jul 20, 2023Looks like the issue for me is something to do with DHCP (yes I had the range set as 100-200) I set up my own DHCP server and set the lease time to 1 week and it's been stable ever since
Netduma-Fraser
Jun 08, 2023NetDuma Partner
What were the issues you were having exactly? Then we can determine whether Armor may have been the cause.
Raustal
Jun 12, 2023Guide
Hey there! The router would give me errors when trying to login. I would get some UI loading problems, which I do not remember, and I would have to factory reset my router every so often. It has been a while since I had that problem. I was just curious about Armor because I was thinking of giving it another try and did not want to spend the money if it was buggy, or others were having issues with it of some sort.
- Netduma-FraserJun 12, 2023NetDuma PartnerUI loading could potentially be Armor yes, it's hard to give a definitive answer on this one, perhaps wait for the next firmware first which should be a big improvement then you could try it again.
- RaustalJun 12, 2023Guide
Thanks for your quick response and suggestion! You are always a great help around here!
- w0rmw00d6Jun 20, 2023TutorSince updating to this firmware, YouTube is very unstable. I can't watch a single video to completion without it frequently buffering. WiFi dropouts are more frequent. This router has been a pain to use since purchasing a couple years ago. I was hesitant on updating due to frequent issues and all this has done is proven me right.
