Aug 11, 2024Guru - Experienced User
New - XR1000 Version 2 - Firmware Version 1.1.0.22 Released - Hot Fix
NOTE: This FW is for Version 2 of the XR1000 gaming router line. This version of FW is NOT compatible with hardware Version 1 of the XR1000 router series product line. The label under the router sho...
bmjen
Feb 24, 2025Aspirant
I am getting a 403 Forbidden when trying to download this firmware file.
Netduma-Fraser
Feb 24, 2025NetDuma Partner
If you click on the page so you can read the release notes and use the link there it doesn't work for me either. If you click the download button on the download/firmware list then it will work.
- bmjenFeb 24, 2025Aspirant
Can you provide the direct URL? I've tried both and they are the same URL with the same Access Denied XML page. I've tried this on Chrome and Edge.
- Netduma-FraserFeb 24, 2025NetDuma PartnerI've just tried what I mentioned again and it's not working now unfortunately ChristineT could you look into this if possible please?
