Mar 01, 2024Guru - Experienced User
New - XR1000v1 Firmware Version 1.0.0.72 Released
Security Fixes: 02/20/2024
- This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
NOTE: This FW is for Version 1 of the XR1000 gaming router line. This version of FW is NOT compatible with hardware Version 2 of the XR1000 router series product line. The label under the router should display a XR1000 v2 or version 2 text information on the label for a version 2 XR1000. Version 1 XR1000 will not display a version number text on the label.
Download Link:
https://www.netgear.com/support/product/xr1000.aspx#download
Firmware Update Instructions:
- To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/XR1000.aspx#docs
- https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: It's recommended to factory reset and setup from scratch after applying this FW update.
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
Adjust IP range as needed if you have more than 100 devices.
Be sure to make a backup configuration to file after the router as been setup:
Saves time if a factory reset is needed.
This article applies to:
- dracktwAspirant
how do you set up the range ?
