Jul 20, 2024Guru - Experienced User
New - XR1000v1 Firmware Version 1.0.0.74 Hot Fix Released
Security Fixes: 06/21/2024
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
NOTE: Th...
- Oct 02, 2024
After updating and reboot, screen hung on redirect. After waiting 10mins, I went to the router home address and tried to log back in. After entering user/pw, the router threw this error:
Tried just turning the router off and back on and got same result. Decided to factory reset, and I got a partial wizard that allowed me to set things up at least. Then the redirect threw this error again.
I now cannot get into the router to modify any settings, and apparently factory reset doesn't restore the firmware version. Been on hold with 24/7 support in queue for over 30 mins now. I guess at least I have internet access and the wi-fi setup worked so I have that too. But outside of that I can't set ANYTHING else. This is thoroughly disappointing!!
Edit: Confirmed I used the correct firmware for my router version. Attempted login using a private browsing window and no errors. Something changed in the firmware versions that one of my browser extensions was blocking and wouldn't open in a regular window. Am able to access all settings now. đ
Jul 30, 2024Guru - Experienced User
So had my XR1000v1 online for 6 days plus and working good:
First speed test thru Connection Benchmark didn't get a good test so 2nd test try did:
Seems like maybe NTP and Time Zone issues maybe fixed on this version of FW:
