Nov 04, 2021Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.130 Released
New Features:
Supports DumaOS 3.0 features.
Security Fixes:
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com...
Nov 07, 2021Guru - Experienced User
So this just happend a few minutes ago, I lost internet access on my Windows PC while connected to the XR450. I was using a ASUS GT-AX11000 in bridge mode connected to the 2.4Ghz radio. I thought maybe the ASUS was not working right so I rebooted it. No internet. So I changed it to connecting to 5Ghz on the XR450. Still no internet. So I disabled the ASUS connection and connected my same PC to ethernet connection to the XR450. Still no internet.
I pinged the router successfully.
The Onboard Connection Benchmark ran and was successful and reported correctly.
Ooklas installed speed test app on Windows could NOT get a connection thus would not run.
I noticed this in on the web page:
Nothing seen on the networking monitor section.
After checking the web pages on the router, I rebooted it. After it came back to ready, internet is accessbible again.
I only have a couple of devices connected anlong with my Xbox 1 which was not on.
Network Monitor now shows activity:
CAX80 modem mode > XR450.
A factory reset and setup from scratch was performed after v130 was applied the other day.
FYI to those telnet users, Telnet is no longer seen on the debug page.
I'll keep an eye on this and see if it happens again. Debug logs are now running.
- Netduma-FraserNov 07, 2021NetDuma Partneraaronibm21 Vaya a la página de Información del sistema y al panel de Rapp, haga clic en el menú de opciones y cámbielo a 5. Luego reinicie desde la interfaz y espere 2 minutos antes de acceder. Es importante esperar tanto tiempo para que las funciones tengan la oportunidad de cargarse correctamente.
FURRYe38 keep us posted, most likely the same issue from the previous firmware that NG needs to fix, we're talking to them about it currently.- aaronibm21Nov 07, 2021Luminary
Fraser, de verdad, eres un crack . siempre me resuelves todas mis dudas, muchas gracias, ya me funcionan de nuevo.
