Nov 04, 2021Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.130 Released
New Features:
Supports DumaOS 3.0 features.
Security Fixes:
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com...
PSPatricko
Nov 08, 2021Aspirant
Hey there all, I've just updated my XR500 with the latest firmaware. Everything is working fine, except the Speed Test. I mean, it's working but it shows weird info. I have more than 700mpbs in download, but in speed test it barely goes to 300/400mpbs. Upload seems fine and pings also looks good. Can someone tell me why it shows almost half of my download speed? I'm not doing anything in the background... All I did was to set QoS on 3500km from my location and 100ms ping, that's all.
- Netduma-LiamNov 08, 2021NetDuma Partner
¿Es esto con QoS habilitado? ¿Dónde está midiendo sus velocidades, en Connection Benchmark o utilizando la prueba de velocidad de terceros?
PSPatricko I can't see your image yet as it's not been moderated. Are you measuring these speeds through Connection Benchmark or a third-party speedtest? Can you run both and compare the results?
- PSPatrickoNov 08, 2021AspirantEverything was on the image, results from speedtest.net and directly from router. On Speedtest.net I'm getting full speed results and in router they are much lower.
- aaronibm21Nov 08, 2021Luminary
tienes puesto el xr500 como bridge , o como router??
es decir, lo has conectado al router de la compañia por la boca 1 del router original???
o bien, has quitado el de la compañia y has puesto el xr500 como principal??
