Nov 04, 2021Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.130 Released
New Features:
Supports DumaOS 3.0 features.
Security Fixes:
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com...
conkerick
Nov 08, 2021Tutor
I have been testing the update for two days now:
1) I don't know if the DHCP problem was solved. I have it disabled (as a precaution).
2) The router did not hang or reboot itself. In version .120 it crashed and restarted every 3-6 hours.
3) In version .114, which was more stable for me, the CPU load was constantly high, now it stay at "normal".
4) The UI loads noticeably faster and runs very smoothly.
5) Network monitor does not work, does not show any information.
It seems that we finally may be able to start enjoying our router.
- ANGELsorryNov 08, 2021Aspirant
im having alot of problem with mine did the update. and keep losin wifi and lan port wont work any fix ?
