Nov 04, 2021Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.130 Released
New Features:
Supports DumaOS 3.0 features.
Security Fixes:
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com...
aaronibm21
Nov 10, 2021Luminary
Buenas tardes, con la ultima actualizacion , despues de haber restaurado de fabrica el router xr500 , cual seria la configuracion optima para poder jugar con mi ps5 en el Qos??? si lo pongo en automatico , la red de mi casa se viene abajo y no funcionan ni los dispositivos wifi.
Gracias
- FURRYe38Nov 10, 2021Guru - Experienced User
In inglese per favore
Gracias
- aaronibm21Nov 10, 2021Luminary
Good afternoon, with the latest update, after having restored the xr500 router from the factory, what would be the optimal configuration to be able to play with my ps5 in Qos ??? If I put it on automatic, my home network breaks down and not even the Wi-Fi devices work.
Thanks
- Netduma-FraserNov 10, 2021NetDuma PartnerFor remote connection, ensure that the XR is setup to get an Open NAT I.e if it is behind another router then that router is in modem/bridge mode or has the XR in the DMZ.
What do you mean automatic - auto setup? What settings do you have currently?
