Nov 04, 2021Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.130 Released
New Features:
Supports DumaOS 3.0 features.
Security Fixes:
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com...
DredPirate13
Dec 20, 2021Apprentice
After going to the .120 beta, factory resetting, upgrading to .130, factory resetting, everything seems to be working except for traffic prioritization. When I go into QOS, i just get a pop-up notification saying that 'Device is not found' and the traffic prioritization never populates, just stays in the loading state.
- DredPirate13Dec 20, 2021Apprentice
Actually, it's not working even when I factory reset on .120.
What I figured out that I needed to do was revert back to the system provided .114 firmware update, then factory reset, then update right to firmware .130 and it seems to work fine now. I haven't factory reset due to the known issues so I will just backup my settings and wait for the next firmeware update.
- Netduma-LiamDec 21, 2021NetDuma Partner
OK, thanks for sharing that, let us know if you run into any further issues.
