Nov 04, 2021Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.130 Released
New Features:
Supports DumaOS 3.0 features.
Security Fixes:
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com...
DredPirate13
Dec 20, 2021Apprentice
Actually, it's not working even when I factory reset on .120.
DredPirate13
What I figured out that I needed to do was revert back to the system provided .114 firmware update, then factory reset, then update right to firmware .130 and it seems to work fine now. I haven't factory reset due to the known issues so I will just backup my settings and wait for the next firmeware update.
- Netduma-LiamDec 21, 2021NetDuma Partner
OK, thanks for sharing that, let us know if you run into any further issues.
- techie12Dec 29, 2021Tutor
Hello. My XR500 has been resetting the internet connection a few times a day past few months. I've been reading these before and I ended up last month upgrading to this version. I then factory reset it and it worked for about a month. As of yesterday it started resetting again for whatever reason randomly. The XR500 resets, gives amber lights, and turns back on. Yesterday I tried fixing the DHCP with .2-.49 and reserved the clients I have to those IPs, it did not work. I'm still getting these scripts in the logs. I really need help in resolving this issue, as these interruptions are extremely frustrating and I don't know where else to go.
[DumaOS] Cloudsync DPI result 'nil','failed to sync', Wednesday, December 29, 2021 14:21:07
[DumaOS] Cloudsync DPI 'skipping mirror', Wednesday, December 29, 2021 14:21:07
[DumaOS] Cloudsync DPI 'HTTP sync failed', Wednesday, December 29, 2021 14:21:07
[DumaOS] HTTP download failed with code '404', Wednesday, December 29, 2021 14:21:07
[DumaOS] DHCP new lease allocated., Wednesday, December 29, 2021 14:21:05
[DumaOS] DHCP new event., Wednesday, December 29, 2021 14:21:05
[DumaOS] Ubus object 'com.netdumasoftware.qos' added, attempting to bind pending, Wednesday, December 29, 2021 14:21:17
[DumaOS] NSS delete root for interface 'br0', Wednesday, December 29, 2021 14:21:17
[DumaOS] applying qos for zone lan, Wednesday, December 29, 2021 14:21:17[DumaOS] NSS delete root for interface 'brwan', Wednesday, December 29, 2021 14:21:17
[DumaOS] applying qos for zone wan, Wednesday, December 29, 2021 14:21:17
[DumaOS] taking down IFB, Wednesday, December 29, 2021 14:21:16[DumaOS] Ubus object 'com.netdumasoftware.benchmark' added, attempting to bind pending, Wednesday, December 29, 2021 14:21:17
[DumaOS] Ubus object 'com.netdumasoftware.benchmark' added, attempting to bind pending, Wednesday, December 29, 2021 14:21:17[DumaOS] Ubus object 'com.netdumasoftware.qos' added, attempting to bind pending, Wednesday, December 29, 2021 14:21:17
[DumaOS] Ubus object 'com.netdumasoftware.qos' added, attempting to bind pending, Wednesday, December 29, 2021 14:21:17[DumaOS] Ubus object 'com.netdumasoftware.pingheatmap' added, attempting to bind pending, Wednesday, December 29, 2021 14:21:17
[DumaOS] Ubus object 'com.netdumasoftware.pingheatmap' added, attempting to bind pending, Wednesday, December 29, 2021 14:21:17[DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Wednesday, December 29, 2021 14:21:16
[DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Wednesday, December 29, 2021 14:21:16[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending, Wednesday, December 29, 2021 14:21:10
[DumaOS] Ubus object 'com.netdumasoftware.trafficcontroller' added, attempting to bind pendin, Wednesday, December 29, 2021 14:21:10
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound, Wednesday, December 29, 2021 14:21:10
[DumaOS] Ubus object 'com.netdumasoftware.trafficcontroller' added, attempting to bind pendin, Wednesday, December 29, 2021 14:21:10- Netduma-FraserDec 29, 2021NetDuma Partnertechie12 to clarify, you set the DHCP range to start at .49 or end at .49?
