Nov 04, 2021Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.130 Released
New Features:
Supports DumaOS 3.0 features.
Security Fixes:
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com...
connorcoolbeans
Jan 14, 2022Tutor
Hi all... any update on when we can expect to get an updated firmware from netgear that fixes these issues regarding DHCP/router dropouts?
Also would appreciate if anybody could explain how to revert the software back to the original software provided with the router or an earlier version before these issues started occuring and provide a link to it please.
Been unable to use my XR500 these past couple of months.
Netduma-Fraser
Jan 14, 2022NetDuma Partner
We're waiting on NG to test and give the go ahead for our changes, unsure whether it will feature their fix, it should do.
Download the relevant firmware from the support site then downgrade in the way that you upgrade by uploading the file .56 may work but do keep in mind you will lose security updates by downgrading.
https://kb.netgear.com/000061157/XR500-Firmware-Version-2-3-2-56
- mathmath51Jan 19, 2022Apprentice
Hi,
Any news regarding the next versionof the firmware, or at least some confirmation of the DHCP bug will be fixed ?
Thanks
- Netduma-LiamJan 19, 2022NetDuma Partner
We're currently working on implementing the latest DumaOS improvements and additions into the XR range, that will then go through our internal testing once done and then be sent to NETGEAR for their testing. I don't have an ETA as to when this might be as it depends how well it does through testing. The latest improvements include a series of major patches and fixes from our side which may help with DHCP issues, though I don't know for sure as it hasn't been through testing.
- DHCPissuesJan 28, 2022Aspirant
Hello. I had to create a new account because I forgot the old email, whatever not important. So I've done the "fix" by assigning all of the end users on the router and giving them an IP address outside of the .2-.49 window and reserved those. It's been working for about a month. My old username was techie12, and now as you can see, it's been exactly a month or so. I've done no changes since that fixed my issue, but now today it's back at it and it's reset 3 times already today.
Any other temp fixes to help me out?
