Nov 04, 2021Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.130 Released
New Features:
Supports DumaOS 3.0 features.
Security Fixes:
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com...
Netduma-Liam
Jan 19, 2022NetDuma Partner
We're currently working on implementing the latest DumaOS improvements and additions into the XR range, that will then go through our internal testing once done and then be sent to NETGEAR for their testing. I don't have an ETA as to when this might be as it depends how well it does through testing. The latest improvements include a series of major patches and fixes from our side which may help with DHCP issues, though I don't know for sure as it hasn't been through testing.
DHCPissues
Jan 28, 2022Aspirant
Hello. I had to create a new account because I forgot the old email, whatever not important. So I've done the "fix" by assigning all of the end users on the router and giving them an IP address outside of the .2-.49 window and reserved those. It's been working for about a month. My old username was techie12, and now as you can see, it's been exactly a month or so. I've done no changes since that fixed my issue, but now today it's back at it and it's reset 3 times already today.
Any other temp fixes to help me out?
- Netduma-FraserJan 29, 2022NetDuma PartnerCan you provide a screenshot of the LAN Settings page please?
- DHCPissuesJan 29, 2022Aspirant
Here you go.LAN
All I see is a triangle in those posts, can you see the image?
- Netduma-FraserJan 29, 2022NetDuma PartnerI can't see them, they have to be approved by a moderator before they become visible, I will check back in an hour and hopefully they will have been approved by then.
