Nov 04, 2021Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.130 Released
New Features:
Supports DumaOS 3.0 features.
Security Fixes:
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com...
DHCPissues
Jan 28, 2022Aspirant
Hello. I had to create a new account because I forgot the old email, whatever not important. So I've done the "fix" by assigning all of the end users on the router and giving them an IP address outside of the .2-.49 window and reserved those. It's been working for about a month. My old username was techie12, and now as you can see, it's been exactly a month or so. I've done no changes since that fixed my issue, but now today it's back at it and it's reset 3 times already today.
Any other temp fixes to help me out?
Netduma-Fraser
Jan 29, 2022NetDuma Partner
Can you provide a screenshot of the LAN Settings page please?
- DHCPissuesJan 29, 2022Aspirant
Here you go.LAN
All I see is a triangle in those posts, can you see the image?
- Netduma-FraserJan 29, 2022NetDuma PartnerI can't see them, they have to be approved by a moderator before they become visible, I will check back in an hour and hopefully they will have been approved by then.
- Netduma-FraserJan 29, 2022NetDuma PartnerAll looks fine there, could you provide a log from when the issue happens - it has to be provided before a reset/reboot otherwise the relevant information will be lost.
Basically the same stuff as my first post, same errors, etc on 2021-12-29 02:36 PM on page 3.I don't really know what else I can do to stabilize this.
[DumaOS] config write 'com.netdumasoftware.desktop.database', Saturday, January 29, 2022 13:42:27
[DumaOS] config write 'com.netdumasoftware.desktop.database', Saturday, January 29, 2022 13:42:26
[UPnP set event: add_nat_rule] from source 192.168.1.51, Saturday, January 29, 2022 13:08:59
[UPnP set event: add_nat_rule] from source 192.168.1.51, Saturday, January 29, 2022 13:08:58
[UPnP set event: add_nat_rule] from source 192.168.1.51, Saturday, January 29, 2022 12:23:58
[UPnP set event: add_nat_rule] from source 192.168.1.51, Saturday, January 29, 2022 12:23:57
[UPnP set event: add_nat_rule] from source 192.168.1.51, Saturday, January 29, 2022 11:38:57
[DumaOS] DHCP lease change., Saturday, January 29, 2022 10:11:10
[DumaOS] DHCP new event., Saturday, January 29, 2022 10:11:10
[DumaOS] DHCP new lease allocated., Saturday, January 29, 2022 10:11:07
[DumaOS] DHCP new event., Saturday, January 29, 2022 10:11:07
[DumaOS] applying qos for zone lan, Saturday, January 29, 2022 10:10:52
[DumaOS] applying qos for zone wan, Saturday, January 29, 2022 10:10:52
[DumaOS] Ubus object 'com.netdumasoftware.pingheatmap' added, attempting to bind pending, Saturday, January 29, 2022 10:10:49
[DumaOS] Cloudsync Ping Heatmap result 'true','Cloud is up to date', Saturday, January 29, 2022 10:10:49
[DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Saturday, January 29, 2022 10:10:48
[DumaOS] Ubus object 'com.netdumasoftware.benchmark' added, attempting to bind pending, Saturday, January 29, 2022 10:10:48
[DumaOS] Ubus object 'com.netdumasoftware.qos' added, attempting to bind pending, Saturday, January 29, 2022 10:10:48
[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending, Saturday, January 29, 2022 10:10:48
[DumaOS] Ubus object 'com.netdumasoftware.trafficcontroller' added, attempting to bind pendin, Saturday, January 29, 2022 10:10:48
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound, Saturday, January 29, 2022 10:10:48
[DumaOS] All dependencies loaded, starting, Saturday, January 29, 2022 10:10:48
[DumaOS] Dependency loaded 'com.netdumasoftware.geofilter', Saturday, January 29, 2022 10:10:48
[DumaOS] Dependency loaded 'com.netdumasoftware.qos', Saturday, January 29, 2022 10:10:48
[DumaOS] NSS delete root for interface 'br0', Saturday, January 29, 2022 10:10:47
[DumaOS] applying qos for zone lan, Saturday, January 29, 2022 10:10:47
[DumaOS] NSS delete root for interface 'brwan', Saturday, January 29, 2022 10:10:47
[DumaOS] applying qos for zone wan, Saturday, January 29, 2022 10:10:47
[DumaOS] taking down IFB, Saturday, January 29, 2022 10:10:47
[DumaOS] Cloudsync Geofilter result 'true','Cloud is up to date', Saturday, January 29, 2022 10:10:45
[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending, Saturday, January 29, 2022 10:10:42
[DumaOS] Ubus object 'com.netdumasoftware.trafficcontroller' added, attempting to bind pendin, Saturday, January 29, 2022 10:10:42
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound, Saturday, January 29, 2022 10:10:42
[DumaOS] config write 'com.netdumasoftware.qos.settings', Saturday, January 29, 2022 10:10:42[DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Saturday, January 29, 2022 10:10:48
