Nov 04, 2021Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.130 Released
New Features:
Supports DumaOS 3.0 features.
Security Fixes:
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com...
Feb 20, 2022Guru - Experienced User
And FW builds don't come over night!
Raf1212
Feb 27, 2022Apprentice
FURRYe38 yes sorry you are right they do not appear overnight, so now look at the date of the beta version 120 (2021/03/17) you look soon it will be half a year, because those were the last changes, because 130 had only security fixes (so come does not count)
- FURRYe38Feb 28, 2022Guru - Experienced User
And it's only been 3 months since v130 appeared. I've seen releases take upwards of 9 months to come out.
FYI, I did ask if anything was in the pipe, nothing has of yet. I'll keep checking here and there.You have to keep patient.
Thank you.- BartXR700Mar 10, 2022GuideUPnP don't work at all with latest 3.0. Last working build is .66. New and old beta 3.0 give same port on 2 different PC in same network when we try to play same game for ex. Destiny 2.
- Netduma-LiamMar 10, 2022NetDuma Partner
Thanks for reporting, how did you notice this? Where are you noticing the duplicate ports? What port is it, 3074?
