Apr 12, 2022Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.134 Released
Enhancements: 04/12/2022
Remove Funjsq for PR SKU
Various security enhancements
Bug Fixes:
Fixes an issue where the name of an attached device cannot be changed in the device manager th...
- Jul 27, 2022
I recommend that you leave the DHCP IP address pool range set to a smaller range. You don't have to use the default range. I personally never use the factory range on any NG router. Also this provides room for static IP addressed devices as well. I use .100 to .150 as I only have around 30 devices. Plenty of room for additional devices if and when that happens.
We hope so, however don't have that info.
blackshirt40
Apr 13, 2022Guide
when i click the QoS option i am greeted with a device not found, also when i try to run the connection benchmark nothing happens
- FURRYe38Apr 13, 2022Guru - Experienced User
Did you factory reset the router and setup from scratch after loading the FW?
What browser are you using?
Be sure to clear out browser caches before entering the routers web page.
- blackshirt40Apr 13, 2022Guide
i tried the hard button reset on the back, held for ten seconds. it rebooted the router but saved info was still there, then i did the factory erase option(think that is what its called) and that did reset it. so long answer is yes. I have also tried both chrome and edge
- Netduma-LiamApr 14, 2022NetDuma Partner
You may need to downgrade back to .130, factory reset, then upgrade to .134 and don't reset. That'll fix it for you.
