Apr 12, 2022Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.134 Released
Enhancements: 04/12/2022
Remove Funjsq for PR SKU
Various security enhancements
Bug Fixes:
Fixes an issue where the name of an attached device cannot be changed in the device manager th...
- Jul 27, 2022
I recommend that you leave the DHCP IP address pool range set to a smaller range. You don't have to use the default range. I personally never use the factory range on any NG router. Also this provides room for static IP addressed devices as well. I use .100 to .150 as I only have around 30 devices. Plenty of room for additional devices if and when that happens.
We hope so, however don't have that info.
blackshirt40
Apr 13, 2022Guide
i tried the hard button reset on the back, held for ten seconds. it rebooted the router but saved info was still there, then i did the factory erase option(think that is what its called) and that did reset it. so long answer is yes. I have also tried both chrome and edge
Netduma-Liam
Apr 14, 2022NetDuma Partner
You may need to downgrade back to .130, factory reset, then upgrade to .134 and don't reset. That'll fix it for you.
- FURRYe38Apr 14, 2022Guru - Experienced User
WIth v.130 applied, I applied v.134 over the top then used the ERASE fuction to factory reset the router. Used MS Edge to set up the router and walked thru the setup wizard.
I recommend clearing out all browser caches prior to walking thru the setup wizard.
The "Device not found" message appears on the QoS page:
Wired speeds are to spec:
Connection Test is working however the download doesn't reflect what external speed test app says:
Something I noticed this morning, I had used the top WiFi enable/disable button yesterday to turn OFF the wifi radios. Left them OFF over night. I looked over this morning and found the 5Ghz radio enabled LED on the front of the router this morning. I used the button to enable the radios, then agian to disable the radios, both LEDs turned OFF. I'll check this again later.
- Netduma-LiamApr 14, 2022NetDuma Partner
Thanks for the detail as always, the Device not found error is a weird one but it can be fixed by downgrading to .130, resetting, then upgrading again without resetting after.
Looks as though Connection Benchmark is reporting incorrectly, out of interest can you let me know if you get expected results running a speedtest here:
https://speed.measurementlab.net/
Let us know how you get on with the Wi-Fi.
Ok, speed test for that site linked in MS Edge:
Uplink isn't near to 50Mbps specs.
Got home and WiFI LED is still OFF. I'll continue to check this tomorrow morning.
