Apr 12, 2022Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.134 Released
Enhancements: 04/12/2022
Remove Funjsq for PR SKU
Various security enhancements
Bug Fixes:
Fixes an issue where the name of an attached device cannot be changed in the device manager th...
- Jul 27, 2022
I recommend that you leave the DHCP IP address pool range set to a smaller range. You don't have to use the default range. I personally never use the factory range on any NG router. Also this provides room for static IP addressed devices as well. I use .100 to .150 as I only have around 30 devices. Plenty of room for additional devices if and when that happens.
We hope so, however don't have that info.
domino138
Apr 13, 2022Guide
Upgraded firmware, factory reset via GUI, 30 second press of the reset button on the back just to make sure. Reconfigured all settings - everything seems to be working fine. These are the settings I have different to default:
- Ran the Wizard and added username and password for PPPoE (UK ISP)
- Configure Google DNS instead of using ISP's DNS
- Allowed the router to run its own speed test
- Enable QoS and reduce to give headroom for congestion control
- Ran DSL Reports speedtest and scoring A+ / A / A+ so pretty happy
- Disable:
- uPnP
- WIFI radios (I have separate WiFi access points)
- Media Server, USB and ReadyShare
I don't use the Geo-Filter or Hybrid VPN so cannot comment on those.
Will let you know if there are any issues.
domino138
Apr 14, 2022Guide
I’ve not had a good experience with QOS on this version. Since the upgrade I’ve felt that even normal web browsing performance is sluggish. One of my children said that CS GO was unplayable. I play Factorio and I put in a manual QOS rule in for it (as on the previous version) but latency was noticeably worse (spikes up to 250 ticks).
You can see the actions I took to upgrade in my previous post. I went from v120 to v134. I’ve now downgraded to v130 without a factory reset and things seem to be working fine again.
